Show only
Search instead for
Please integrate 3d Dimensions that can be placed in referance to faces and points in 3D space, Take a look At Solid EDGE, from Siemens. AWESOME SOFTWARE
Having this functionality would be a great benefit to us. Also, being able to constrain two points in one sketch but at different heights. Basically, instead of horizontal/vertical, have align x/y/z.
Apparently this is in inventor fusion; useful dimensions that do not take away from communicating the design are already available in inventor fusion. So, I think the folks right down the hall might have all the code you need to implement this right away!
Please implement 3-D labels and dimensions. I put in a rendering of a very complex model, carefully parametrically designed, into a proposal, and some moron reader "dinged" my proposal claiming that I had "only" put in an artistic rendering, not a "real" developed design, because there were ***no dimensions on it***. So, it is clear that people do not take the 3-D models seriously without the dimensions. It is very important that you implement this. Please.
Also, please add 3-D labels. The ability to label one thingy "bracket" and another "leg" is really really helpful in making people understand your work.
Very much +1000 on this. I find the amount of effort required to locate sketch geometry/3D features to relate to precise points of features in other planes/axes.
