3D Diff Tool
3D Diff Tool
I'd like to be able to see the difference between two bodies. One simple way to accomplish this is to color one red and the other green, and then make a toggle switch to swap the colors. I'm doing this manually, and it's very simple, so a built-in tool should be trivial to implement. A natural extension is to enable the comparison of models across versions, similar to what happens in code repos; a user could simply select a target body and comparison body from other files and versions in their data folder. A more advanced extension to generate a report of each body that's changed and by whom, which would be useful for teams. Thanks for considering.
