[OPEN] Call for feedback: 3D Adaptive > Reduce Air Cutting for 3D Adaptive
dylan_smith
Autodesk Autodesk
Message 1 of 8
dylan_smith
Hi everyone,
It's my pleasure to introduce the new improvement to 3D Adaptive, Reduce Air Cutting for 3D Adaptive Clearing. This
change is a public preview feature within Fusion 360's manufacturing workspace.
This change has been made to reduce cycle times and create more autonomy in the programming process .
Attached is a short video detailing the benefits of this new implementation.
We encourage honest feedback.
Thanks!
Dylan Smith
Manufacturing Specialist
Replies (7)
Message 2 of 8
gtprototype
Honestly, based on the video, I can't imagine ever needing it.  Why would I want to re-machine the portion below the remaining material from the previous operation?  The simplest solution would be to adjust the z depth to prevent re-machining.
Dale Speakes
prototype technology
Message 3 of 8
FrodoLoggins
Because the portion below the remaining stock still has remaining stock? Do you ship unfinished parts?
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 4 of 8
gtprototype
@FrodoLoggins  Thank you for your salty reply.  I re-watched the video, I see the value now, however, prior to this change wouldn't it have worked by creating two operations and adjusting the depth of the first where the stock profile is being removed?
Dale Speakes
Message 5 of 8
matthewrjacobs
I have enabled this feature, however I can't find it in the dialog box.   Is this something that runs in the background?
Message 6 of 8
FrodoLoggins
If you checked off "Reduce Air Cutting for 3D Adaptive Clearing" in Preferences > Preview Features, then it's enabled. Nothing else you need to do.
Message 7 of 8
matthewrjacobs
Well, then it hasn't improved the run time on the test part. 😞
Message 8 of 8
FrodoLoggins
This feature comes in handy usually on the second setup after milling the first side, it doesn't speed up every roughing operation.
