Hola por primera vez e tenido problemas con mi fusion 360 algunos apartados no se pueden manejar de manera optima desde hace una semana y media, el caso esta en que el navegador daba varias obciones de trabajo y ahora solo se queda en blanco, ya no puedo mover las barras de modificaciones, como tambien al guardar mi dibujo no puedo manipularlo, se traba o se congela como dicen y se cierra solo, no se si es un problema nuevo o alguien mas lo a tenido, por favor diganme como solucionarlo si debo dercargar nuevamente mi fusion o que puedo hacer.
¡Resuelto! Ir a solución.
Resuelto por Gabriel.Castillo. Ir a solución.
Hello, sorry I'm not able to read in Spanish.
However this is what Google transator gave me:
Hello for the first time and had problems with my fusion 360 some sections can not be managed optimally from a week and a half ago, the case is in the browser gave several obciones work and now only goes blank , and I can not move the bars of modifications, as also to save my drawing no I can manipulate , stalls or freezes as they say and shuts itself , is not whether it is a new problem or someone else what to had, please tell me how to fix it if I dercargar again my fusion or I can do.
Autodesk is the life of ideas and soul of inventors
So if I understand correctly the "el navegador" (translated as "the browser") is empty when You try to access the data?
By "el navegador" do You mean the data panel on the left side of the Fusion window?
Alex
Hi
What about spanish translation of fusion 360
Any idea if there is a spani
Hi
Any idea if there is a spanish version?
If not, how can I translate it myself?
When downloading fusion 360, which file is the one that I have to translate?
Thank you
sh version?
Thank you
Hi Everyone. I speak with @00Hector in spanish.
Estimado @00Hector dos aspectos:
1) Para ayuda mas facil en tu idioma, te recomiendo publicar en el nuevo foro que tenemos de Fusion 360 - Espanol (https://forums.autodesk.com/t5/fusion-360-espanol/bd-p/337 ).
2) Marca este foro en tu navegador para futuras consultas y trata de compartirlo con los demas.
Para trabajar con tu caso, favor de indicarnos el hardware que estas usando.
Saludos
Hola Héctor,
Yo también he tenido el mismo problema durante las últimas semanas como comentas tú.
Lo que yo he podido hacer y me ha funcionado es cerrar y volver a abrir el programa, y siempre haciendo un Logout antes de cerrar.
Si por casualidad tienes otra cuenta adicional, prueba entrando con la otra cuenta y luego con la principal tuya, eso también me ha servido a mi.
También he leído en los foros y noticias que Autodesk ha tenido algunos problemas con los servicios A360, me imagino que puede ser algo de eso.
Saludos.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
.Hola Héctor.
El problema es netamente de conexión a internet y puede estar combinado con los recursos de la computadora.
Si estás usando laptop, intenta que esté cableada al internet.
Si tienes Windows 10, recuerda que consume mínimo 4gb de RAM, quiere decir que la combinación de la velocidad de conexión a internet más, los recursos del hardware pueden darte este tipo e fallas.
Mientras solucionas los recursos del pc, debes esperar unos 10 minutos para Fusion pueda darte toda la visualización del Data Panel.
Recuerda de asignar kudos si esta información te pareció útil.
Si consideras que es una solución a tu inconveniente, entonces no te olvides de asignarlo como solución.
