Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
UNDO function not working anymore thince the last update (2.0.9640)
9 REPLIES 9
Message 1 of 10
franck.malepart
1292 Views, 9 Replies
everything in the title, since the last update, when i press undo or ctrl+z nothing happened
This problem make the program totaly unusable. usyually i press undo 10 times per minute to adjust the component position.
I've tried to reinstall the software but nothing changed
I need a fix asap, I lost so many time on it unless making work, I've deadlines !
9 REPLIES 9
Message 2 of 10
additional informations :
- the problem occur only on files updated from old versions (working on new projects created with this version)
- the problem occur on all the team (differents computers and accounts)
so i'm able to start new projects but not continue my old ones
Message 3 of 10
mrjdmcd
in reply to: franck.malepart
I'm having the same issue.  For existing projects "undo" no longer functions.  This is making working on my schematics and PCBs very difficult.  Any ideas on a fix or work-around?
Message 4 of 10
yiqiu.han
Hi, @franck.malepart @mrjdmcd
Thanks for letting us know the problem, Would you please share the data correspond and the last saved date with us? An archived f3z that contains the whole electronics design information would be very fine. You can open electronics design and go to file>export button to export it.
Thanks!
Message 5 of 10
Thanks for the support, You will find a corrupted project attached to this post.
I've found a workaround to fix the issue but the fix isnt' perfect :
- create a new empty electronic project
- copy the schematic and the gerber files to the new project
- link the copied files to the new project
At this point the undo work agin but all the tags are lost durring the process. Unfortumately, I use tags to open older versions that we've already produced. So with this fix, i can't work anymore on my old boards, it's very usefull in term of support for my clients.
I think there is a problem durring the conversion of the files in version older than 2.0.xxx to the version 2.0.9640. The copy function create files directly in the new versions and UNDO works.
I hope that this problem will be fixed quickly, all the companny is paralized
Message 6 of 10
yiqiu.han
Thanks for sharing the design data!  @franck.malepart
The workaround is a choice but not let the user feel comfortable, I understand that.
I have shared your data and working status with the development team, Will let you know when there's any update.
Message 7 of 10
yiqiu.han
in reply to: yiqiu.han
We have found a better workaround. You could simply close the 3D PCB tab, after that operation executed on schematic and board can be undo as usual. In this way, copying data to another project is not needed.
And we will try to address the fix as soon as possible.
Message 8 of 10
thanks, the workarround fixes the problem.
After closing the 3D file, i'm able to do an undo. I regenerate the 3D file of the board and now everything is working.
Thanks a lot, We'll be able to continue our work
Message 9 of 10
yiqiu.han
Hi, all
The latest Fusion 2.0.9849 has been deployed and it contains the fix for the issue mentioned here!
Please have a try🙂
-Yiqiu
Message 10 of 10
tplH938C
The undo button disappeared on a CAD drawing. What the heck is going on with Fusion?
