Hide all polygon pour fills not working anymore after the update
rbkyorem
rbkyorem
It shows the warning 3D pcb and 2D pcb is not synced but I can still see copper pours.
rbkyorem
Selecting polygon edges and unticking show fill works but this takes time on multiple layer boards...
Command line for ripup also does not work.
This needs to be fixed ASAP!!!
halseth
Just ran into this after system reset and Fusion updated to 2.0.9719 (unsure of previous rev).  Hide all Polygon Pour fills doesn't appear to function anymore. You can hide by toggling the show fill on the object itself, BUT if you move anything within the fill space it recalculates immediately and shows back up. This seriously hampers visibility if pours are used for major ref/pwr nets or leads to the annoyance of a bunch of airwires that don't need to be manually routed by doing pours at the end. Either way this issue results in a significant productivity hit. Any work arounds would be appreciated.
panpan_fan
Hi @rbkyorem  @halseth
I hope you are doing well!
Sorry for this issue. It will be fixed in the next release. I will keep you updated when we release it.
Workarounds for this issue:
  1. If you close the 3D PCB and then continue to Hide Polygon in the 2d PCB, then it will work.
  2. Or you can remove the 3D PCB link and view 3D PCB. Save a new version then continue to work.
Please have a try, thanks!
Panpan Fan
keqingsong
Hey rbkyorem, the Polygon tool should work as expected now - a fix for this was included in our latest product update
V.2.0.9849.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
