Failed to get 3D model from library
carl.j.barker
carl.j.barker
Just learning to use the electronics functions in fusion and have a problem
IC's 4,5, and 6 all use the same package but....
Why?      Is it me?        Is it a bug?       Am I just going nuts?
HelenChen-AutodeskQA
Hello @carl.j.barker ,
Sorry to hear that you're having trouble.
Thank you very much for your files, we will investigate this issue.
Could you please try to move the IC5 in your board file a little bit and then view 3D PCB again? Thank you for checking.
Helen
Helen Chen
Principle QA for AutoCAD Windows
Sorry @carl.j.barker , need your help to check one more scenario.
Could you please delete the problematic IC5 in the schematic file > Re-added a new IC5 in the schematic file > View 3D PCB again?
Helen
Helen Chen
Hi @carl.j.barker ,
We could reproduce this issue now and will keep you be posted if this issue is addressed.
Thank you very much for your files.
Helen
Helen Chen
anders.nelsonJW4B6
Observer
Observer
I'm having a similar issue. I made a copy of a design (proj/sch/pcb/3d files) with new names, then removed the previous links in the project file and re-added the sch/pcb files with the new names. When I export to 3D, none of the 3D models in their respective part libraries appear on the board.
I updated all the libraries in Library Manager. All the parts had 3D models added via the web interface on library.io. However, it seems like the PCB is using parts only from Fusion Team.
How can I get the 3D models to reappear? How can I link the existing components to the correct library (fusion team or library.io)?
