Vertical Wind Turbine Project
This is the Vertical Wind Turbine I'm working on:
This will sit on top of a 3 metre wooden post. The outer diameter is just over 1 metre. A belt will be attached to the other wheel which will be connected to a motor to generate electricity. The height of each blade is 146mm. This is just a prototype which I intend to 3D print, if it works then I will print many more.
Link copied
