Turn curved surface into equivalent flat surface.
ljbdeshler
ljbdeshler
I have some curved surfaces and I want to (paper) print decals to stick onto the surface (on the real part, not on the design).  Is there a way to turn the curved surface into the equivalent flat surface?  Then I can use a paint editor to make the decals.  Thanks.
dsouzasujay
Hi @ljbdeshler
Can you Attach prior designs that you have already completed in Fusion 360?
Can you File>Export your *.f3d file to your local drive and then attach it here to a Reply?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
g-andresen
If it is a single curved surface, it can be done with the sheet metal tools in Fusion.
For double curved surfaces, Fusion is not suitable.
Here you can try your luck with EXACT FLAT or MESHMIXER.
günther
