Trace a picture or image from an image using 360 or inventor
zenkustumz
Message 1 of 14
zenkustumz
Can anyone tell me if there is a way to import an image (lettering) or image (shape) and make it into a 3d item?
Replies (13)
Message 2 of 14
TrippyLighting
Sure. YOu insert the image as a Canvas and then start a sketch on that same plane you inserted the Canvas onto and trace the shape with the available tools such as line, arc, spline etc.
Then you can extrude the profile that you sketched, provided it contitutes a closed profile. Usually in the sketch environment a closed sketch "loop" turns yellowish to indicate that it's closed.
Message 3 of 14
HughesTooling
You can import a image and manually trace.
Link to HELP
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 14
zenkustumz
Awesome.. Thank you so much.. Awesome.. Sorry for the newbie questions..
John
Message 5 of 14
AnandSomani
Just one addition which came to my mind...
If you have the SVG file, you can also use the Sketch > Import SVG command.
It will directly create the sketch for you,if that's what you meant.
Thanks.
Anand
(Autodesk Fusion Developer)
Message 6 of 14
I'm having the same problem. I'm new to the whole 3D modeling thing and i need some help with figuring out hoe to import an SVG because it's not and SVG but is there a way to make a regular PDF into an SVG?
Message 7 of 14
yqliu
You can't  make a PDF into an SVG in Fusion 360, but you can make it in Adobe Illustrator.
Richard
Message 8 of 14
great! Now ambarassingly I am trying to import the Jpeg to the platform and I m not able to copy paste, drag and drop, or import, do you have any more tricks. as you can tell I m very Novice<
Message 9 of 14
JDMather
I learned to do this by going through the Help>Tutorials....
Message 10 of 14
Hi, i have a lot of experience in Illustrator, and have a fully spec'd and detailed SVG drawing of an electric guitar, and whenever i import it to fusion and go to extrude it, I lose all of the detail, i can only extrude 1 part and then i cant do anything. Any help would be massively helpful.Screen Shot 2017-06-26 at 3.04.54 PM.pngScreen Shot 2017-06-26 at 3.21.00 PM.pngScreen Shot 2017-06-26 at 3.21.50 PM.png
Message 11 of 14
davebYYPCU
The Browser on the left side needs to be open.
Then you can make sketch 1 visible again, to do more operations from that sketch, but with browser closed you can't get to the visibility lighbulb.
Might help...
Message 12 of 14
thank u so much it helped me alot
Thanks.
Message 13 of 14
zenkustumz
Is there a way to resize the Svg once it's imported can't seem to figure it
out. Does it need to be by itself (it's own file)
Thanks for your assistance.
John
Message 14 of 14
davebYYPCU
The SVG data - generally - should be in its own sketch when it arrives, you can edit it in Fusion, if needed.
Change size - you can scale the sketch articles with Sketch > Scale,  Fusion will fail if you select the anchor point as part of the data being scaled, work out the new size as a scale factor, no other input allowed, (Desired size /  Actual size)
Might help....
