You have several miniscule ark/line segments floating around that would need to be deleted. such as this arc here-
you have also moved one of the "rings" off the sketch plane, creating a 3d sketch. going to be hard to constrain that, and even then, 3d sketches sometimes won't show as fully constrained even when they are. (a long standing bug that is unlikely to get fixed anytime soon).
a few suggestions-
-symmetry/mirror constraints have also always been problematic (ie buggy), would suggest not using them, there are better ways that have the added benefit of also visually showing design intent.
-2 options for dealing with that ring that needs to be turned 90deg. you can put a line where it needs to be, put a plane at an angle on that line, and create a sketch on the that plane for you ring.
or (and possible better)
just create the first ring, but make it a separate component. then you would joint an instance of that component in place. pattering many components seems to be less computationally heavy than patterning bodies. plus you only have to make the ring once.
