Slicer- 3D Construction Techniques- 3D Slices
Hello !
I have been toying with Slicer, and I was excited that it has a 3D slice option, but when I select this construction option (it is the last one) it does not provide the cut layout and sheets/parts.
Can anyone pull it up and test if it works for them? Maybe I was misled and it is more of a viewing option and not viable for creating 3d sliced models
Thanks!
jodom4
Can you post the file you're trying to slice? I'll see if I can replicate the problem on my end.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Hi Jon,
I've attached the file
When I switch to 3D slices, as you can see, there are no plans or ability to modify form!
Thanks for your help,
Paige
chrisjmulhall
 Try this plugin, it does what "3D Slice" is supposed to do.
https://ekinssolutions.com/sliceitup/
