Sketch does not recognize a closed shape
johnhoge
johnhoge
I've been working on a sketch for a while now and all of a sudden it decided not to recognize a closed shape. Even a circle drawn from scratch shows up without the highlight indicating fusion recognizes it is closed.
Should I just delete it and draw it again?
jhackney1972
You did not supply your model so the forum users are guessing.  One, make sure Show Profile is checked in the Sketch Palette.  Two, make sure you are not sketching in 3D mode.  Three, if you did, in the sketch, select the geometry and right click and select Move to Sketch Plane from the context menu.
John Hackney, Retired
