Running FEA simulation from .STL file
Hey y'all, I am new to Fusion 360.
I have a few skull models in .stl format that I am trying to fun FEA analysis on. I cleaned up and solidified the models in Meshmixer. The skull is in parts.
I inserted the .stl into Fusion 360 and try to do simulation, but the model was not showing up in the simulation.
I have tried remeshing to quad in other programs, but still failed to convert into Tspline.
I have no idea what went wrong. I have attached the .stl file.
If someone can shed some light on this, I'd really appreciate it.
shekar_sub
Hi chiwang,
Fusion Simulation supports simulation of solids. So if  you can convert the STL (triangles) into a water-tight solid then it should show up in the Sim workspace and you should be able to simulate it.
After I open the file I can Right Mouse button in the browser on the Mesh and convert it to a body. Then when I go to Simulation workspace I can apply loads and constraints on a body with thousands of faces. However I do not recommend simulating with this workflow. The mesh will fail with self-intersection error. The conversion of mesh to body just created faces for all the triangles and you have innumerable faces.
So if you have converted the mesh to a solid in another software system and try that would be greatly appreciated.
Regards
shekar
