Message 1 of 10
04:51 AM
I am practicing building drawings.
I made this drawing using lines and rotate. The measurements are all right, the design is right.
Problem. It doesn't appear that the rotation parts are all joined. In the hole in the top of the stem it appears that the hole is divided on the axis that was rotated. Then from the top view, it appears that the original part is still there.
The combine command did not solve this.
Is this a visual interpretation that is fine or did I do something wrong.
Thank you.
