Question about Points during Scale Function
krummeck
krummeck
Good Evening
I have for years battled with the scale function. Not the amount of scale, when I get there, but the point about which the design will scale. The videos I have watched on the subject a trainer will select the design to be scaled, randomly choose a point about which the design will scale and its scale amount, and its done.
I have recently had a design with 74 points on it, (complex Design); not one of those points would select at the point required in the function.
I need to ask, what governs the points eligibility, and how can I use the correct point each time I need to scale something?
Please advise
Kind Regards
Warren Krummeck
Replies (10)
TheCADWhisperer
krummeck
Cool, here it is....
TheCADWhisperer
The sketch is poor quality - I would start by fixing the problems with the sketch.
Examples to follow in a minute...
Missing Tangents?
Blue geometry?
Missing Dimensions?
Unconnected points?
More overlapping geometry...
Would you like to learn how to do this correctly?
krummeck
Why did it distort so badly, or have you moved it around like that?
krummeck
Are you perhaps saying that only constrained points can be used in the Scale function?
jeff_strater
first clarification:  it seems you are referring to Scale Sketch here, not the general Solid/Surface Scale.  Is that correct?
If so, then what you are seeing is probably an effect of Fusion's selection system:  An item cannot be selected twice.  So, if you window select the geometry to scale, it grabs points as well as curves.  So, all those points are now selected in the Entities selection.  So, they cannot also be selected for the Point selection.  There are numerous ways to get around this.  One way is illustrated in the screencast below - change the filter to select only curves for the Entities selection.  This works in your sketch because there are no "free" points in your sketch - all the points are attached to curves, and so will scale just fine.  Then, you have to go back and turn the filter back on to select a point to scale about.  Many people want to scale about the origin, so just avoiding that origin point in your Entities selection will work fine.
What @TheCADWhisperer is referring to is general sketch goodness criteria - it is always better to have your sketch more constrained than not.
Jeff Strater
Engineering Director
krummeck
Wow that is awesome thank you. The secret revealed. When I am making up something that I feel should be around for a long time I try constrain it a bit more, bad excuse I do need to try harder. Anyway I will go look for theCadwhisperer youtube channel, considering he is so keen to straighten out my world.
Thank you again
TrippyLighting
Generally I would try to avoid the scale function.
The sketch you imported is of poor quality and the "deformations" when trying to constrain the existing sketch comes from the fact that very little is tangent to begin with, and the sketch is of poor geometric quality.
I've re-created the sketch with proper dimensions and constraints:
Now you can change individual dimensions to get to the size you want.
TheCADWhisperer
@krummeck
Actually, get lazy!
When you get the techniques of sketching mastered it is actually far less work.  I would have to work very hard to make the sketch as you did, but to do correctly is pretty easy (even @TrippyLighting (see Message #9) ) can do it.  😄
In general it is often best to do Fillets as placed features rather than in sketch.
colinskaminski
I often have to scale dxf logos from art software. They are a nightmare. I always scale them in their own document and choose the origin as the scale point. I often have to do an hour of repair to make it all work and rarely can I fully constrain the sketch.
It can be done with patience if you have to.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
