What is the sketch meaning of the different point color.
Black = Sketch point (Got that one)
White ?
Green?
No point? (On some not others)
Solved by DDMFGCOINC. Go to Solution.
Black is a constrained point.
White is an unconstrained point.
Green is the color used for the Fix/Unfix command.
edit*
Pink/Purple is a projected point.
Yellow means there is an error.
I have one point that is colored differently that any other in my sketch. What does this color indicate?
@kshea9RNL8I do not recall doing a project, but I will study that command to see if I did it inadvertently and left something behind. This is at a point where two lines had intersected and are now removed (deleted).
Thanks for the doc!
However, I saw something that I couldn't explain with this info: there are 2 different kinds of purple points on the image attached: "full" and "hollow". Do you know what those mean?
@guillaume.clementYBXLC - excellent question, thanks for asking. The "closed" point indicates a point which is shared by two or more connected lines/curves/arcs, while the "open" representation indicates a point that is just connected to one line/curve/arc:
Thanks Jeff. Your posts have been incredibly helpful to me as I learn my way around Fusion 360.
