Just logging back into Fusion for another project after a few weeks of using it. I got my new project all drawn up and switch into manufacture to create a tool path. I believe I'm doing everything as I have in the past however after I create the path and go to simulate something looks different and I don't get the triangle (play) button on the bottom. A pop-up window opens up so I know its in some sort of simulation mode.. however I just don't see that Im able to run the tool path I created.
I attached the file below. I looked around on here a bit but didn't see any simulation issues that really fit what I'm was experiencing. Any help would be great!
Solved by jhackney1972. Go to Solution.
Your model only has the toolpath setup to cut out two holes. This executes just fine on my system. I will export the file and you can see if it works on your system. Maybe just a fluke in the file format.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I really do not know why you are not seeing the Simulation controls but as far as the Toolpath arrows, you only get those if you are using the "Chain" geometry selection method.
John Hackney
Retired
