Pipe command in solid workspace
hejWR6K4
Observer Observer
hejWR6K4
Observer
Observer
Hi.
I'm getting some really strange results.
I'm trying to make panel lines on a model airplane with the pipe tool.
No problems on the fuselage, but on the wings there is no connection with the body when I try a cut command.
On the image I made the "new body" command and the pipe is way off. It should be on the line with the red marking.
Any suggestions?
Thank you
Krister
TrippyLighting
We need to see the model with the full timeline. Export it as .f3d file and attach it post a please.
hejWR6K4
Observer
Observer
When I turned off parametric modeling and do direct modeling it's working just fine. Strange...
hejWR6K4
Observer
Observer
For some reason I can't export as F3D file.
laughingcreek
if you have linked components you can only export .f3z files.  you can attach that if you want (though most on the forum prefer if you break the links so you can export as .f3d. it's way less hassle on this end)
