negative k factor required (but not possible)
travis
travis
I'm running a brand new cnc press brake with new tooling, and trying to bend a 12 ga angle with 1.25" x 1" legs.  Both the tooling company and machine manufacturer has confirmed i'm using 'middle of the road' tooling (not too sharp of punch, not to wide of die... just right)
when i set 12ga (.1046) to a k factor of 0 in fusion I get a flat pattern dimension of 2.096".  My machine states the flat pattern should be 2.053".  Based on test bends, the machine is correct..  for a single bend part I don't really care, however we do 6 bend parts and the difference adds up.  Based on this information I should be setting a negative K factor in Fusion.... but that's not possible.
any help is much appreciated
TheCADWhisperer
Can you File>Export and then Attach a *.f3d file here and indicate dimensions that your machine calculates (if there are also other bends than the one you have already stated.)?
travis
I produced a more straight forward file to show the issue I'm having.  Attached is a 14ga angle 2" x 2" x 2" long.  my press brake flat dimension is 3.78664".  The sheet metal settings in this file have a K factor set to 0 and the flat pattern dimension is 3.819".
Please let me know if you need more information... thanks!
TheCADWhisperer
@travis wrote:
...my press brake flat dimension is 3.78664".
Can you show some sort of verification that the radius of .0747 is set.
travis
You mean in my press brake?  It bases it's flat pattern and back gauge equations on the tooling loaded.  My punch is .063 tip radius.  I changed that in Fusion and now my flat is 3.824"... still too big.
I noticed that each bend seems to be roughly 1/16" over what my press brake tells me.  Could fusion be thinking that i'm coining?  I'm currently air bending and I know there is some material lost when the tooling bottoms out.
