Hi all,
i have a problem with the multiple edge selection per window, which simply wont do the trick for me. When activated, the programm only recognises the edges, but i cannot select all the edges on the surface of the model. As you can see in my picture, I want to select all edges at once, in order to use the piping tool and create a specific lattice as a solid body from a generated mesh, but right now i have to click on every **** edge with STRG. I thought the window mode+only select edges would work for me but apparently it does absolutley nothing....and i don't want to select every edge of the surface manually.
I have already checked the filter boxes ..even T-edges..but nothing works
Any help ?
