Modeling & T-Spline help
MichaelTewasart
MichaelTewasart
I have a question regarding the T-Spline tool.
In Untitled, I used the T-Spline and began creating an object that I desire. I want it to maintain the sharp creased edges. However, when I continue to cover it all up with the T-Spline tool, it ends up looking like Untitled2.
I was wondering how do I make my desired shape that still maintains its sharp creases. I don't want a round object model.
PhilProcarioJr
@MichaelTewasart
A couple of things to point out here...for starters always try to work in quads, you have N-gons on the top of your model.
To get sharp edges all you have to do is select the edges you want to be sharp and use the crease tool on them.
Phil Procario Jr.
Owner, Laser & CNC Creations
TrippyLighting
Select the edges, right-click and select crease from the menu.
However, looking at your browser you may want to go through the video tutorials in the Learn section.
Also, I am not exactly sure why you would want to create this object as a T-Spline. It would be easier to create this with the solid modeling tools.
