I have exhausted all of the different options I have available to me and I can't seem to figure out how to exclusively machine this angled surface with a back and forth machine path starting at the bottom and going to the top. Anyone familiar with GibbsCAM would know about the morph between two curves option. This allows you to create a path ON a surface between two curves (these curves can be open or closed). I'm trying to emulate that exact same path in Fusion360 to eliminate extra air passes and unneeded rapid moves when all I'm trying to do is work my way from the bottom of a chamfer up to the top.
Edit: Added an image for clarity.
EDIT 2:
Using "Ramp" is the closest I could get to my desired toolpath. As you can see it wraps around the side of the solid and always rapids up and over to the start instead of just chaining to each new path. I tried different lead-in strategies and the only one that came close to what I want was effectively a feed-rate rapid with "smooth profile" where I couldn't control the feed or step up.
