Jointing two assemblies
colin.watters
colin.watters
I have successfully joined two components together in F360 but is there a way to join two Assemblies in one go?
When I try it seems to strip a components out of one Assembly and join it to the other Assembly but it leaves the rest of the previously jointed parts behind.
Is that intended behaviour? Can you only grow an assembly one component at a time or can you join two complete Assemblies in one go?
Thanks.
jeff_strater
the usual technique here is to fully constrain your sub-assemblies with a set of joints (could be rigid, or could include motion joints, but the important part is that all components have joint relationships to the rest of the components in that sub-assembly.  Then, all you need is a joint between two components in each sub-assembly to connect everything up.
Jeff Strater
Engineering Director
jhackney1972
Very often, when you are placing Joints between components or between sub-assemblies, in the Joint Preview it would seem the wrong component is moving and disconnecting from a previous joined assembly.  Do not let this deter you, go ahead and commit the new Joint and the rest will follow back into position.  In the Screencast I try and show this behavior.
John Hackney, Retired
TrippyLighting
I suggest you share your assembly here.
If you have a personal subscription, then export the design as a .f3z file and attach it to the next post.
colin.watters
Thanks for the replies. So it should work, must be something i'm doing wrong. I was cancelling the joint when I saw other bits left behind so that was probably it . Unfortunately I've got to travel for a few days but will try again when I get back. Thanks again.
colin.watters
Just a thankyou to @jhackney1972 .  Seems I just needed the confidence to hit OK and F360 sorted it all out.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
