Is there a way to join these segments so that I can apply a fillet to the 10 'corners'? I tried using Combine but that didn't change anything. Right now if I try to apply a fillet I get a weird result -
Here is the drawing if that helps -
I have already glued the segments into a ring and need to machine it for a clock face that will go into the circle -
Thanks!
David
David Falkner
