Announcements
Inserting SVG
Inserting SVG
I am trying to insert an SVG file to ultimately create a legend?
I have had a few instances of the program hanging - I am wondering if the image is too complicated/unsuitable?
I have attached it?
I did think about just creating the features on a sketch and extruding them slightly - using the circular pattern tool
but struggled to get the text aligned?
How would I go about this? It is difficult enough to centre text, but I also want to rotate it around an axis?
Chris
jeff_strater
Hi @Anonymous,
Yes, you can use that SVG in Fusion.  It will be slow, though, mostly because of the way the "filled" letters are drawn, with lots and lots of lines:
Fusion will try to interpret each of those lines as a valid sketch line, which will slow down the entire system.  if you can get a version of this SVG without the pseudo-fill lines, you will have a much better experience, I think.
Jeff
Jeff Strater
Engineering Director
Thank you for the reply, apologies but I didn't realise I had had a reply...
I created the SVG by drawing this in TurboCAD and exporting it as an SVG - so I will try and find
an outline font - I did get a progress bar when I inserted it but wasn't sure how long to wait, looked
like Fusion had hung? I can create the 'tick' marks in Fusion by using the circular pattern tool so only really
need the text.
I have tried to create the text etc in Fusion but it a very difficult to align it and rotate it hence using
TurboCAD?
Regards
Chris
I have now recreated the original TurboCAD drawing using an outline font and exported that as an SVG file,
and this worked beautifully - I imported it into a sketch and can extrude the fonts, very easy and perfectly
lined up 🙂
Chris
