Message 1 of 15
Insert, Unlink, Position, and Feature Edit
I have realized that the biggest downfall of F360 for my applications will be the lack of being able to edit features after positioning unlinked components. I use mulitple stand off components in our equipment designs which consist of identical components that only vary in length. I have created a base file that I can insert into my design, unlink, and position. My intent is to then use this position to drive the length of each stand off to a common faceplate...but because of the timeline order when I edit the extrusion feature that drives the length it defaults back to its position that the component was created in. Not real sure how to get around this, seeing that the captired position can not be moved before the feature that the component is generated from.
The way I have got around this is by creating a minimal base length and then doing a second extrude in position, but doing this makes my OCD flare up slightly. I also have to go back and add the mounting holes for each stand off seperately instead of having a base compnent that would just need a single length edit, this adds time and frustration.
THOUGHTS??,
Brandon.
THOUGHTS??,
Brandon.
