Imported dwg empty
Imported dwg empty
alexandwirtz
Message 1 of 26
Imported dwg empty
alexandwirtz
Dear community, I've imported this dwg via upload to the data panel in fusion but once opened it seems to not contain anything. When I open it in edrawings everything is displayed fine.
I then converted the dwg to dxf and other versions of dwg with no success when uploaded and opened.
I do not have autocad to tweak more options, can someone make the attached file work in fusion? (better show the way how to if possible)
Thank you!
  • dwg
Replies (25)
Message 2 of 26
g-andresen
DXF files saved in Autocad are ignored.
Try to get the parts from the manufacturer or  via Insert > manufacturer part.
günther
Message 3 of 26
alexandwirtz
Thanks for your reply, the drawings are not on any platform but come from our suppliers of extrusion profiles. The original file i received from them is a .dwg file.
Message 4 of 26
TheCADWhisperer
@alexandwirtz wrote:
I do not have autocad to tweak more options,...
@alexandwirtz
Original geometry was Regions.
I moved to Origin and Exploded into lines and arcs.
Save As dxf and then Import into Fusion (see Attached).
It helps to have a full understanding of AutoCAD geometry types.
Message 5 of 26
HughesTooling
@TheCADWhisperer Are regions just a surface? I opened the DWG with Rhino and the "Regions" import as a surface, might be Rhino is just converting to something it supports. But what I found with a bit of experimentation is Fusion seems to ignore single unjoined surfaces in DWGs.
If I create new surfaces in the file they are also ignored but if I join another surface to create a polysurface Fusion sees and imports the polysurface fine. So it seems like there's a problem importing unjoined surfaces from a DWG.
Here's my test. I've added 2 surfaces, one joined to one of the original regions.
Only the polysurface import into Fusion.
Using STP instead works fine so unjoined surfaces are not a problem for Fusion in other formats.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 26
alexandwirtz
@TheCADWhisperer : Thanks for your response and adjustment of the data! For non autocad users it would be great to not worry about this kind of problems... I thought it would be more easy with dwg files to go from one to the other system. Fusion should be able to convert dwgs in some form after uploading...
Thanks for your help.
Message 7 of 26
wersy
Fusion is able, but not in the free version.
Message 8 of 26
alexandwirtz
I'm on a subscribtion, but so far I do not have the experience that a dwg is importet without problems. So a conversion to the degree that I can work with the file is not the case.
Message 9 of 26
wersy
When the option of dwg import was still available, I only imported bodies. That went without problems.
I have no experience with dxf import.
Message 10 of 26
alexandwirtz
What can i forward to a supplier that uses Autodesk, to make sure fusion can read dwg or dxf files with no problems? What are the best settings etc.?
Message 11 of 26
Warmingup1953
Ask for .dxf. It was conceived and born to be the CAD Tower of Babel!
https://en.wikipedia.org/wiki/AutoCAD_DXF
Message 12 of 26
alexandwirtz
Even with importing dxfs the problems persists, not all lines are displayed. Viewing the file in edrawings shows all lines and it seems to be OK. See attached screenshots.
The dxf is from the supplier, maybe you can take a look at it and find a solution?
Message 13 of 26
HughesTooling
@Phil.E Can this be looked at? Seems like and unjoined surfaces in a DWG\DXF are not converted to a surface when translated. Open polysurfaces and solids are fine.
See my post #5 above for more details.
Thanks Mark
Mark Hughes
Message 14 of 26
Warmingup1953
aaa.jpgaa.jpgbb.jpgThe attached .dxf file is a .dxf of the complete Drawing Sheet...Not of the Cross-section of the extrusion (s)
Message 15 of 26
Phil.E
@HughesTooling If you can please send me a file and succinctly explain what is expected, I'll file an improvement request for the translation developers. A file and a few short steps, please send to phil dot eichmiller at autodesk dot com.
When the most recent dxf is opened in AutoCAD, it throws errors for missing shx fonts and missing xrefs.
This means that the Fusion translators are going to have the same problems.
Solution:
  • remove all dimensions, text, title blocks, etc. prior to export as dxf
  • explode all xrefs (or whatever makes them not xrefs)
Next, I notice the extrude profile imports into Fusion very far from the origin.
Solution:
  • Move the profile to the origin prior to export as dxf
Hopefully this helps. These same steps might work for dwg file type as well.
Conclusion:
AutoCAD creates many objects that are only valid in AutoCAD. Fusion, and any other application that consumes these DWG/DXF files is at a disadvantage. Fusion, and other apps, simply do not have the full code stack of AutoCAD available to address these objects that are used in AutoCAD workflows.
In order to consume information from AutoCAD today, it is helpful to strip it down to the very essential information and no more.
Could Fusion do better? Sure, but there might be a requirement to include a new UI to help you clean up these files on the Fusion side: layer control, text font control, xref control, etc. This is not on the Fusion development road map at this time. We can look for automatic ways to translate files like this.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 16 of 26
HughesTooling
@Phil.E I'm not too worried about the dimensions, text, etc.. If you import the DWG in the first post you don't get anything, no sketches or surfaces. If I open this file in Rhino I find the profile is a  surface,  @TheCADWhisperer mentioned this is a region in AutoCad. Not sure if Rhino is just making the region a surface because it doesn't have regions. But what I found is if I add unjoined single surfaces to that file they are also ignored but joint polysurfaces read in fine.
Attached is a simple example.
In Rhino I have a single surface and a polysurface
When this is imported into Fusion only the polysurface imports.
I'm guessing if Fusion imported unjoined surfaces in DWG\DXF it would import the 2 regions in the DWG in the first post?
Thanks Mark
Mark Hughes
Message 17 of 26
HughesTooling
And the same goes for the DXF, there's a region for the main profile. I don't think this needs to be translated as a sketch profile, just a surface would be enough.
If I join a surface to the profile in Rhino it will then import into Fusion.
Rhino
Imported into Fusion. I'm sure people could work from this OK.
Mark Hughes
Message 18 of 26
Phil.E
I'm happy to look into what you propose @HughesTooling but first can you confirm that data like this is supported?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-import-DWG-...
Is the original request to use 3D dwg or 2D dwg? I think it's about 2D dwg.
The reason I ask is that if I follow the instructions in that page, I get this result in Fusion working with the dwg attached.
Lovely extrusionsLovely extrusions
Note: DWG files from AutoCAD and other software can contain data that Fusion 360 cannot read. Fusion 360 can only import DWG files containing 2D sketch geometry or 3D solid bodies. For AutoCAD drawings - open the file in AutoCAD and purge the file, making sure to remove XREFs and images.
So I think non-solid bodies are not supported.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 19 of 26
HughesTooling
That's the problem, what do you do if you don't have AutoCAD.
Non-solid bodies do import, single unjoined surfaces don't. DWG\DXF are quite useful because they allow you to import pretty much anything. A DWG\DXF can have solids, polysurfaces, meshes and sketches and import fine but it seems not single surfaces.
You can import single surfaces in STP or IGS but you can't import sketches, this has been requested on the old ideastation and was marked as implemented but it never worked. The request for IGS and STP to import sketches entities has come up a few times. You can view IGS\STP files with curves on the cloud but when translated you only get surfaces, solids.
Thanks Mark
Mark Hughes
Message 20 of 26
HughesTooling
@alexandwirtz  Have you tried QCad or one of the other AutoCAD clones to see if they open your DWG files correctly?
Mark
Mark Hughes
