I can't move a simple circle...
saslanis
saslanis
So this is the case.
I made a cirlce in an existing sketch. But i can't move it by simply selecting the perimeter and click and move. I can only move it by right click and select move from the menu or by selecting the and moving the center. Is this the normal behaviour?
And an extra question.. how can move the circle to just touche two other lines? Tangent only works on lines.
thanks
Replies (7)
davebYYPCU
Offset those two lines, by the radius, make the centre point coincident to the two offset lines.
Might help....
jeff_strater
Dragging on the circle will change its radius.  Dragging on the center will move the center, and therefore the circle.  If the circle has a dimension, then dragging anywhere on that circle will move the center.  Or, as you point out, there is the Move command that will allow you to move the circle.  Seems like plenty of options there.
Tangent does not only work on lines.  A circle can be made tangent to line, other circular arcs, and ellipses.  You cannot make a circle tangent to a spline curve, that is a current limitation of the sketch solver.  @davebYYPCU's approach is the usual work around for this limitation.
Jeff Strater
Engineering Director
Can someone PLEASE PLEASE advise what am I doing wrong and why the heck I can't move a simple circle? I have designed few things already and printed them on my 3d printer successfully, but this Move command is driving me nuts!! Please explain what am I doing wrong and why the circle doesn't move. (see video) While trying to make a new video, i have been able to move the circle once! But since then I wasn't able to replicate that. What am I doing wrong please ?
jeff_strater
the issue occurs at 0:19 of your video:
you have created your circle so that its center is coincident with the sketch origin.  The sketch origin is a fixed point and cannot be moved.  You need to remove this coincident constraint.  Select the center point, and the coincident constraint will appear:
select that constraint and delete it:
and you will be able to move the circle
Jeff Strater
davebYYPCU
What am I doing wrong?
Placing the circle on the Origin, knowing that you want to move it, without removing the coincident constraint first.
Connected to the Origin - has to be disconnected first, or place the circle in free space and dimension it back to the Origin for correct placement.
Might help.....
Thank you! I thought about it when I closed the app and went to bed, then your advice came to my mail and I felt so stupid 🙂 I usually start my drawings from the center, but rarely need to move them initially. This time I used canvas to help me draw a rough shape of that object and needed to move the circle. Very nicely explained. Thanks a lot!
TheCADWhisperer
@Anonymous wrote:
This time I used canvas to help me draw ...
I move (and scale) the canvas such that a logical datum on the image is placed at the Origin Center Point.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
