How would you model a seashell in Fusion 360?
LMF5000
LMF5000
By seashell I mean a shape like the above. It has me stumped because the underlying shape has smooth curves in all three axes, and the grooves all extend from the center (but in fusion we can only sketch on flat planes).
I tried using the sculpt workspace but didn't make much headway. I had some success sketching the perimeter and using a loft but I feel I'm approaching it wrong. I would be very grateful if someone were to show me the best practice on how to do it.
Accepted solutions (3)
Replies (32)
chrisplyler
Are you wanting all the natural variance? Or are you asking about a mathematically uniform, sloping, wavy, radial array?
LMF5000
Both would suffice, the original aim was to 3D-print a seashell-shaped vase but I am also keen to expand my skillset.
What I've been trying to do was the former - that is, importing the attached image as a canvas and using it to guide my sketches. But I suppose a wavy radial array on a 3D-curved surface will also "look like" a seashell shape to a layperson so it would still work.
chrisplyler
Here I have:
1. Sketched a Spline. (pretty straight)
2. Used a Circular Pattern to array that spline in a seashell-like way.
3. Moved every other Spline up higher.
4. Moved many individual control points around slightly to introduce variety.
5. Added a wavy Spline at each end to connect all the radials.
6. Lofted (in the Patch workspace) between the two wavy ends, using all the radials as Rails.
chrisplyler
If you're talking about something like this, then I just sketched a circle at the bottom, a wavy spline at the top, lofted between them and finally shelled it.
LMF5000
That looks very promising! I'm going to try experimenting with 3d splines like you made, and the loft command in the patch workspace. Thanks for the tip!
I don't suppose there's a way to make it in fewer moves, to avoid selecting and moving alternate splines?
LMF5000
I see what you were thinking, but no, what I had in mind was to use a pair of mirrored seashell surfaces to make this sort of vase:
Image result for seashell vase
TrippyLighting
I'd do this as a T-SPLine/Sculpt/Form. Here's a start:
LMF5000
That's exactly what I was trying to do in sculpt mode. But I tried starting from a plane and it was getting quite involved to align all the lines to features on the shell. How did you get to that stage?
TrippyLighting
Basically you'll have to have an edge for each valley and peak. You could actually sketch the base mesh on a piece of paper and then model it flat in the sculpt workspace. I guess that's the key. Model a flat view first and then pull the valley edges and vertices down.
I'd have to make a screencast to explain that.
LMF5000
First attempt with the spline-loft method in patch workspace. Not a bad start!
LMF5000
That's what I struggled with - how do I create edges that align with the valleys and peaks? Any way to insert them manually or somehow align them with a 2D sketch spline?
TrippyLighting
Here is a screencast has how I got started. It;'s not the fastest method, but that's OK.
undefined
chrisplyler
Doesn't light up.
Also, you can take your impressive Sculpt environment skills and stick them where the sun don't shine you dang showoff. Smiley Wink
TrippyLighting
Mommy, mommy, @chrisplyleris being mean too me whaaaaa....
PhilProcarioJr
@TrippyLighting
Shouldn't there be a tree in that image somewhere? Smiley Tongue
Phil Procario Jr.
Owner, Laser & CNC Creations
chrisplyler
@TrippyLighting  knows I'm just throwing some sarcastic, friendly ribbing at him. I hope.
PhilProcarioJr
@chrisplyler
Yeah he does, as was I. One thing I can say about Peter is he can take a joke.
Phil Procario Jr.
TrippyLighting
If i'd combine both of your suggestions, then that would combine into a glowing tree resembling something radioactive 😉
LMF5000
Wow, thank you for taking the time to make a 15-minute screencast. Using the alt+click to add geometry was a brilliant idea, I was actually trying to add it as a face each time (so it was taking me 4x as many clicks). I also learnt what the "weld vertices" tool does, so thanks for that too :).
I should have some free time this evening, I'm going to download the f3d you attached and try and figure out how you closed off the shell and gave it a flat square base.
Thanks for the help, you guys rock!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
