I saw this video:
https://knowledge.autodesk.com/community/screencast/abdde246-cf2c-42d3-b086-7b4e411774d3
There you can see how to modify the number of pattern objects by double clicking on it's central poinz. But I have a problem with this.
I also have a circular pattern. At the same position of the patterns central point I have other points like starting points of lines, starting points of construction lines etc..
Now I want to double click the patterns central point to change the number of patterned objects from 3 lets say to 5.
But If I double click on the central point the small popup menu of the pattern (as shown in the above video) does not open.
This is becuase other points on the same position lay on top of the patterns central point and get selected.
OK now I thought I could press left mouse button for around 2 seconds and then I get a list of all objects at the same point.
The list appears and I can see 'Profile' and I can choose this - but this causes only a single click not a double click which I need.
Then I tried to change the selection filter but unfortunately for pattern central points there is no selection filter availabe :-(.
So how can I double click a patterns central point if other points are placed at same location as the patterns central point?
Thanks!
