How to rotate a body around its z-axis?
Hi
I try to rotate a body around its z-axis (and not move it in any direction).
I would expect that as soon as I click the move-typ "rotate" the origin (x, y and z-axis) of the body would be shown, but there is nothing.
Can anybody please help me?
Thank you.
Alain
g-andresen
try these
günther
wersy
You must select an axis first.
This can be an edge of a body.
Thank you guys for your tips.
Doesn't a body have its own origin (like in any other 3d-Software)?
This origin in my case should be the center of gravity, isn't this possible?
g-andresen
Components have an Origin. Bodies are parts of them.
I recommend that you study the function of different joints.
günther
Joints? Is that something to smoke? Haha 🙂
Sorry, I'm jost joking.
Thank you, I will give it a try.
Just a sitenote that reminds me to the term of "joints":
Why does Autodesk call a function "move/copy" if there is also "rotating" behind it?
"Transform" instead of "move/copy", from my point of view, would generate less confusion 😉
Excuse me if I understood something wrong.
jeff_strater
A Body does not have an origin.  A Component does have an origin - that origin will move with the component when it is positioned (with a Joint or Move Component, etc).  That component origin, however, has nothing to do with the Component's center of gravity/mass
Jeff Strater
Engineering Director
