Hi @Anonymous,
Thank you for posting your question in the forum. I think you might find this post as very useful.
It explains how to create a spiral along a path.
http://forums.autodesk.com/t5/design-validate-document/spiral-along-a-path/m-p/5401817#M13906
I hope you find this information useful to find a starting point
I put together a simple script for generating helical curves if you need it as well:
https://github.com/tapnair/HelixGenerator
Hi @Anonymous,
Thanks for keeping us updated.
You can follow these steps to use the Helix Generator and create a twisted pair:
A. Create two sketches with helical splines with the HelixGenerator.
How to install and use the HelixGenerator is explained by these steps:
https://github.com/tapnair/HelixGenerator/archive/master.zip
B. Edit one sketch and rotate the 3D spline by 180 degree
C. Use the "Plane along Path" feature and create two planes at the end of the splines
D. Create two skethces and sweep them along the splines
Here is the public link to the test file which I have created.
Please, feel free to use it and modify the file.
I hope this helps.
