Announcements
How to find the minimum circle diameter?
isakandersson85
isakandersson85
Hi. Let's say I have a part that looks like this:
How can I find the minimum diameter of the outside circle? Of course, trial and error would work, but I was wondering if there's a way to find it automatically. Like a parametric dimension or something like that?
The reason I'm asking is that I need to figure out what the minimum stock dimension can be, assuming that round stock is the way to go which it obviously is in this case.
etfrench
Coincident constraint between the center of the construction circle and the center of the line. Add tangent constraint to the construction circle and the projected arc.
ETFrench
isakandersson85
I was looking for a more general solution that works for any shape.
Like this shape for instance:
etfrench
Draw a line between the arc centerpoints which are furthest apart, then follow previous steps.  Attach your file(s) to the thread if this doesn't work for you.
ETFrench
Warmingup1953
MichaelT_123
Hi IsacAndersson85,
There are multiple options to address your circumstance.
At first …
On the shop floor … wrap a flexible stripe around the object of interest. Measure the resulting diameter or approximate it from the stripe length. Note in this way… you save on the F360 subscription
The second.
If you are pure-pedant-loving-precision, F360 can offer; open the attached file to … have fun with a different approach. You will find two sketches. One facilitates finding the minimal circle eclipsing a profile, and the other profile enclosing a circle. The profile consists of only a single spline here, although an appropriate algorithm could permit any outline constitution.
Now … lets Gambol Begins!
Open one of the sketches and mouse-drag the side of the rectangle or 'rotate' it by its internal construction lines. Try to position the triangle and the subscribed/inscribed to it circle so that the latter entirely eclipses a spline profile (or vice versa).
Share our experiencehow many hours it takes to receive a reasonable result? State diameters of the circles.
Well … it will not be easy … but it might be enjoyable for some.
continuation of this method at the end of this post.
The third.
F360 API offers two bounding regions (boxes) functions. They output external XY-min-max and oriented minimal rectangle outline of selected objects (2D & 3D).
Unfortunately, internal outputs for these functions are not available. Algorithmically they would be much more complex. Similarly, min-max sketch/body circle subscription/inscription is not implemented in API also. In this case, algorithms are almost trivial.
Consider posting such a request … and we will see what will happen.
DON'T SCROLL TO THE END OF THE POST.
… as it states, the Gambol Hack.
Gambol Hack:
Most humans have genetically built in their brain triangulation computer. We always use it to measure distances around us … yes ... by triangulation. Fire yours once more and intuitively find the larger (smaller) triangle. Constrain-Fix one or two of its vertices. The process of finding the solution will be much quicker.
Regards
MichaelT
MichaelT
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
