How to create multiple slots in surface along body (Sweep along a face?)
https://a360.co/2vq8w1h
So I have this small project, where I have an golf handle that I will put some electronics in.
I need to make a small slot / cut-out on the outside of the handle.
Normally I work with simple shapes like a cylinder or a box, and then it is easy to just extrude or create a extra shape to use as cut-out model.
For this my guess is that I need to use "Sweep" function, but I need to get the path to sweep on.
How can I obtain a "path" from my body part? - I need it 4 times along the body, and the body is changing shape along the axis.
I have made a small picture showing where I would like to get a "profile" of the surface slot cut.png
Solved -
Found this!
Sry for not makeing the right research - just needed the right keywords 😛
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/screencast/Main/Details/46b2933...
