Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to create a surface from the end of an extrusion
1 REPLY 1
316 Views, 1 Reply
How can I create a surface from the end of this extrusion so I can extrude again.  Im trying to add wing tips to the end of the wings.  The wings are a symetrical extrusion of an airfoil sketch.
1 REPLY 1
jeff_strater
You should be able to do this.  Use Edit Form, select the outer edges (as in your image), then hold down Alt and drag:
Hope this works for you,
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
