How can I rotate the other way?
lemelman
lemelman
I've designed a section of a model that consists of a small table mounted on an axle at one end and supported by a split stay underneath. The axle joint and all 3 stay joints are revolute.
If I drag the end of the table down, the stay 'bends' properly at the centre, but bends upwards instead of down. If I drag the stay centre down, then it works as required, so how can I get the stay to do that when I drag the table?Start drag.jpgDragging the table.jpgDragging the stay.jpg
davebYYPCU
Use the Joint limit, to prevent the unwanted direction.
Might help....
jhackney1972
It may be an overkill for your application, but this Blog Article and Video shows you how to reverse the direction of rotation of a standard Revolve assembly joint.
John Hackney, Retired
lemelman
Thanks daveYYCPU, that did it just right.
lemelman
Thanks for the good idea John, you're right, it is rather overkill for this problem, but I've learnt something new.
