Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Hole Table in Drawings?
3 REPLIES 3
gmdimarzio88
1013 Views, 3 Replies
 These were made in Solidworks and I was wondering if Fusion can do the same thing? The holes are marked, then added to a table instead of cluttering up the drawing with arrows.
3 REPLIES 3
aaronkcap
in reply to: gmdimarzio88
Yes, but the current way is kind of tedious to do. Place a text box next to the hole and then label it; after that go to tables menu and select table, then from the ui box click where it says reference and select empty table and populate it. I know it can be a lot of work especially in the design from the picture but it is the only way that I know of to do that.
etfrench
in reply to: aaronkcap
Try asking this in the API forum.
ETFrench
gmdimarzio88
Thanks for the help!
