Announcements
Hole size for M3 screws
josh_l
josh_l
Hi there,
I'm relatively new to this so please excuse the basic question. I am designing threaded holes into a design for the first time, which will be professionally CNC punched and threaded by a manufacturer. The material is 2mm thick aluminium sheet.
If I am using the hole tool in Fusion360 to create a hole to fit an M3 screw, should the actual hole diameter be 3mm or are there other allowances to consider? In other words, is the thread itself cut into the surrounding material in addition to a 3mm hole diameter, or do I need to make a smaller hole? I'd love to get it right the first time to save money and time on the prototyping process. If anyone has any experience with this or even a helpful educational link that'd be great!
Thanks!
g-andresen
here´s M 3
günther
HughesTooling
If you use the hole tool and set it to add the thread it will resize the hole to the correct tapping size.
Mark
Mark Hughes
Owner, Hughes Tooling
josh_l
Thanks Mark, that's great. I had made some wrong assumptions about the "Tapped" hole type, but that's just what I needed. It's always nice when F360 can do the maths for me.
HughesTooling
Guess I better point out the size the hole is resized to is the minor diameter and the tapping size will usually be the nearest drill size. So if you create a 2d drawing set the dimension to 1 decimal place.
The XML file Fusion uses to create threads actually contains the tap drill info so hopefully one day you'll get access to this in the 2d drawing workspace in a hole call out.
Mark
Mark Hughes
josh_l
Thanks! That's helpful!
Livar.Stangeland
It's actually quite simple to find the drilling/hole size for metric thread.
In general counts for holes ;
Thread size (M3 = Ø3 outer/screw diameter in mm) minus pitch (0.5 mm form M3 ) equals drill/hole size (Ø2.5)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
