@sjeffff wrote:
The source of the problem is related to the 6 sided shape. I do not know if it is possible to get the desired effect you want by using some mathematical formula to calculate the dimensions of the circle and the hexagon. In order to calculate how much fit on a circle. I don't think so, but would like to be proven wrong 🙂
I think I've proven you wrong in my previous post. You can use it for ANY shape. It's simple. Divide the number of instance you would like to have into 360-deg, and make the width of your shape that many degrees wide.
If you want hard values, of course, you're going to have to know the radius of the circle and plug that into the equation as well. But since we can design graphically in a sketch, we can set it up so we don't need to do that math. We can instead just lay out our desired slice of the pie and construct our shape within it. If you constrain everything properly, it will even adjust with a diameter change of the circle.
It works if you change the degrees of the pie slice also, although of course you will have to edit the quantity of instance in the pattern to match.
Screencast will be displayed here after you click Post.
3145d348-1fef-413c-a503-26b7b3eb4748
https://knowledge.autodesk.com/community/screencast/3145d348-1fef-413c-a503-26b7b3eb4748
