Help with Parameters
matth
matth
How can i drive a parameter value with a condition on another parameter? For instance in pseudocode:
if (width < 40) then offset = 12, else offset = 6
I have read somewhere using a modulus and dividing by zero to achieve some effect of a boolean operator. but i am not sure how this would work in the condition above.  I would really like to solve this, the last thing i want is to have to abstract out 2 versions of this part to handle the condition.
I have found something like this, should I get it working I will update the forum.
http://www.cadforum.cz/cadforum_en/inventor-trick-conditional-parameters-without-ilogic-tip9630
This will help I am sure:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
When trying I found I could not get ceil or round to work on my existing user parameter:
Thanks again,
Matt
MSH | Matt
matth
47 in + ( ( sign(Width - 45.9 in) ) * 1 in ) * 12
If the difference between the width and 45.9 is negative than the value is less than 45.9 so 0*12 = 0. Else 1*12 = 12 add the value
Done! It works!
MSH | Matt
