@cekuhnen did you by any chance read any of the previous forum posts ?
Yes, we did try that. How else would you do that anyway ?
There are two main issues with this model :
1.
In my initial attempts the 2nd from left strip I was only able to apply a G1 constraint to the upper/lower boundary in order to even loft this. The models that exhibit that behavior are all attached to some posts so the behavior should not be difficult to observe.
Now that I've changed my workflow (more on that in the 2nd point) the surface quality of the 2 left strips is completely unacceptable and that is a behavior I have observed many times in other models!
It is also observable that there is a horizontal "streak" going through the middle of some of the left most strips, right in the area the middle rail was applied.
2.
There is a workflow issue here for people that come from other CAD applications and that does NOT exist in other CAD applications! The one I am going to discuss first I have explained many times. Fortunately it does not appear in this model, but I have observed this many times in many other models.
The OP created Sketch20 and projected the lines in that sketch onto the curved surface resulting in Sketch21. The goal was to use the projected curves as loft rails. There are two problems with that.
2.1
In many cases and many posts I have demonstrated that in Fusion 360 projected curves , intersection curves and offset splines exhibit horrible curvature problems. In other applications it is very common to use such projected curves to create further geometry and naturally people try workflows they are used to first. In Fusion 360 surfaces created from such curves exhibit the same curvature problems as the curves they are created with. Not a surprise 😉
But, again, in this case that is no a problem. That, of course presents another challenge, because let's assume a user does actually check the curvature of these curves. They are fine in this case. Why should he assume they aren't in the next project ?
2.2
In this model these curves can only be used as loft profiles but not as rails. That limits a users ability to control U and V directions resulting in the undesirable behavior of the Iso curve analysyis tool you observed and described on the EE Slack Channel.
But it does allow you to create a loft with Gx constaints ... for the first strip from the right. In that case you can actually still select G1 or G2 for the rails in the loft dialogue ... for the first rib only, however, When you try to loft the 2nd rib you don't get the same selection:
So what might the user try then:
Lets say that user comes from a software that does not require for the boundary surfaces to be stitched together but they can be individual surface bodies such as this:
He then uses the split faces command 10+ times (not overly efficient either if one might say so) and splits the center and right surface to get his loft rails/profiles. He also cannot freely change what to use for rails and profiles.
But things work out just fine for the fits rib loft, but then for the second loft he also does not get the continuity selection he got for the 1st loft:
I have analyzed hundreds and hundreds of Fusion 360 files created by other users. Sometimes you just work with what's in the model and this was where I ended up. A place any other user could easily end up!
Then with that model as I have it right now, you can stitch everything together and lofting works as one would expect, but in one of the posts above is a model where that stitching removed the entire upper and lower horizontal boundary edge and only left the vertical split lines. Complete bummer!
Yes, you might get lucky as you and Jamie did and take the "right" Fusion 360 "enlightened" path the first time, but if you don't you'll end up pretty frustrated, definitely one you hit the 2nd left rail.
My point her and in the EE slack channel is that there is a lot more work to be done in the surfacing front before Fusion 360 is adapted more by people that come from other applications.
