Fusion hangs when I try to edit sketch
kriomant
kriomant
I have created sketch with 40 splines or so. Then I mirrored them and now Fusion is unusable — when I try to, for example, delete some splines, it just hangs using 100% CPU. I have waited for around 10 minutes and nothing changed.
Can you please check that problem is reproduced on your system and tell my what can I do to overcome this problem?
Try to delete splines pointed by arrows.
Beyondforce
Hi @kriomant,
I have copied the sketch to a new file and it's working just fine. For some reason, I need to zoom in A LOT in order to see the sketch. I don't know how you did it!
Create a new sketch, copy the spline sketch to the new sketch and see if it helps. If not, then create a new file and copy everything in there.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
