I'm following along with a tutorial modeling a board with dovetails.
At the point where Kevin calls the Extrude command and selects the profile to Extrude, in my attempt, Extrude does not seem to see the profile and only sees the face of the already-extruded board.
I created a Screencast showing that if I follow a similar sequence, Extrude will see the square shape/profile and execute the Cut through the board.
In Kevin's, he is building the dovetail geometry in two halves constrained across a construction line.
I have to presume there is still some basic approach to sketch geometry that I don't understand which is preventing me from Extruding. I've followed Kevin Kennedy's steps about four times now and cannot get past this point.
Attached is my tutorial file where the Extrude fails to see(?) the dovetail shape and the square shape(3 lines) at the edge of the board.
I've also had to attach the screencast I made of the simplified apraoch as an mp4 because the usual Upload is not making the video available through this post interface in the My Screencasts dropdown.
What am I not understanding about Sketch geometry or the Extrude command?
Thanks in advance,
Delain
