Export DWG to Visio
Export DWG to Visio
TwistedLogic
Observer Observer
Export DWG to Visio
TwistedLogic
Observer
Observer
Due to Fusion 360's inability to either A. support multiple models in a single 2d drawing and B. support multi-page drawings, I need to use Visio to compile multi-page assembly drawings for complex assemblies.  I can export a DWG file from my 2d drawing, but when I try to import it like any other DWG into Visio I get a corrupted file error.
1.  Am I missing something obvious?  (Probable answer...)
2.  Is there some better way to do what I need to?
HughesTooling
Here's a couple of links that explain the problem with the DWG files.
http://forums.autodesk.com/t5/design-and-documentation/views-are-missing-in-drawing-dwg-export/td-p/...
http://forums.autodesk.com/t5/design-and-documentation/dwg-issues-opening-in-draftsight/td-p/5602156
Mark
Mark Hughes
Owner, Hughes Tooling
Maowen_Zhang
@TwistedLogic, current the output DWG is AutoCAD 2013 version, while Visio (2013) can't handle this version DWG file. If you have AutoCAD or other application, you could save as DWG file to DXF 2007 version, then it could be inserted into Visio. It's on our schedule to improve the output DWG function, but not sure when might finish it yet, will try keep you updated. Thanks for sharing with us!
Lori Zhang (Fusion Development)
