- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I make my sketches in Adobe Illustrator, then I send them to AutoCad, then into Fusion 360. This is my workflow because I have done my tests sending directly from Adobe Illustrator and it never works correctly, unfortunately. Regardless of my workflow, I am wondering WHY my sketches are not closed, and HOW can I check to see where the supposed "opening" is?
screenshot: hovering the extrude opperation over the shape that should be closed, but Fusion 360 tells me it is not.
Before exporting from Adobe Illustrator, I make sure that everything is the same color black, I expand and merge all the black and then convert the shapes to outlines. I then delete all the negative space left behind from the merge, so ALL I am left with is lines that are clearly closed. There's really no way that there could be an opening when doing this method. It's how I create vectors and I am very familiar with how Illustrator operates. My frustration is whenever certain sketches are inserted into a Fusion 360 plane the shapes are seemingly open. I say "certain" sketches because this seems to happen every other time. Sometimes they work and sometimes they don't. What is even more confusing is that sometimes if I m having an issue, I can simply re-save the file, and there is a chance of it working. It seems to happen on some of the more complex designs, which I can understand there being more room for error, but this has become increasingly frustrating.
I have read and been told by a couple forum members that this could just be a bug/error in the way Adobe Illustrator/AutoCad/Fusion 360 read files slightly different, but it's strange that they work sometimes and other times they don't.
If in fact this is just strange bug and I have to deal with it, how can I check where the apparent OPENING is once the sketch is in Fusion 360? It is easy to check in Illustrator, and I make sure to check, which is why this is confusing me.
I don't mind editing/altering the sketch a bit inside Fusion, but I am not familiar with how to "check for openings". Is this something I can check? I would love to find the root of this issue.
Thank you for your time in reading this. This will be a huge help for me,
Mike
*I will attach all the files I am using:
- DXF file
- DWG file
- Fusion 360 file
- screenshots
(I can also attach the Adobe Illustrator file upon request)
