Drawing Issue
Drawing Issue
SlawsonEngineering
Drawing Issue
SlawsonEngineering
When I create a drawing for a component that is at a different orientation that the top level assembly, the views don't show correctly in the component drawing.  Is there a way around this?
mishrani
Hi SlawsonEngineering,
You can try this workaround -
1. In the design, use "Look At" (available in the bottom toolbar) then select the face of the component you want a drawing of.  You'll now be looking at that face head on.
2. Create a new named view of that orientation (Right-click Named Views in the browser)
3. Now when you create a drawing and place the base view for component, select the corresponding named view as the Orientation in the Drawing View dialog.
Hope this works for you.
Niti
mishrani
Niti
SlawsonEngineering
Thanks.  This work around should work for me now.  Will this be fixed in future releases?
Maowen_Zhang
@SlawsonEngineering, thanks to checking with us, it's a known issue (internal tracking ID: FDWG-7794) for us, will do some research to figure out a proper solution for this, Thanks!
Lori Zhang (Fusion Development)
SlawsonEngineering
Thanks!
Murdug
@SlawsonEngineering
As stated this is an issue. It has been logged in IdeaStation. If you agree with the description there please vote for it.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/create-drawing-views-from-local-not-...
