Double click of timeline entry which does Cut/Paste to create sub components
I did cut/paste operations in the Browser tree to move Components to group them as sub-components.  This works fine, and the cut-paste operations appear as timeline entries.
I'm wondering what double-click of the cut/paste entry in the timeline is supposed to do.  In my case, it began some processing, then reported a circular dependency found error.  It wasn't clear to me if it was reporting an error with the existing timeline entry, or if it had attempted to re-execute the operation, and that was creating a circular dependency.
Jay
Below is the error text:
Error: Circular dependency found: from CutPaste plate_lv1_lft:1 to Body->Comp9.
First feature in timeline: CutPaste plate_lv1_lft:1
Last feature in timeline: Body->Comp9
Total 15 features
zhuravliki
The problem is not related to Cut/Paste timeline feature.
It happened to me multiple times. It is very annoying Fusion 360 bug:
When Fusion becomes busy for different reason (auto-saving, calculating, redrawing...) any click on ANY timeline element causes this element, and everything related to it on the timeline, disappearance. Then, 'Circular Dependence' error pops up. I have no idea why left mouse click on the timeline causes the deletion of the elements or features, but it happens to me three - four times a week. It does not affecting simple models just because the Fusion background actions delay is very short on them, and it is very hard to hit timeline element exactly at the same time. For the real models with multiple bodies and not 'just two spheres and one cubic' geometry, Fusion freezes for 5 - 15 seconds every five minutes or more often for performing auto operations. It is very easy to click on the timeline element exactly at that time and create the mess in your model. Undo helps sometimes in such cases, but most of the time you need to close the design without saving and reopen it again. You will be very lucky if you saved the normal copy recently.
It is very frustrating Fusion 360 modeling, with enabled timeline, flaw.
