Distributed Triangular Load Help
amfensch2ARM5
amfensch2ARM5
Hello!
I am trying to run a static simulation on a cantilevered beam for a project in class. I am to apply a triangular distributed load as shown in the picture below. I've built my beam, I just cannot figure out how to change the distributed load from rectangular to the increasing triangle as shown.
Can someone explain how I can apply the needed load?
Thank you!
Screen Shot 2021-12-02 at 10.29.31 PM.pngScreen Shot 2021-12-02 at 10.29.45 PM.png
John_Holtz
Autodesk Support
Autodesk Support
Hi @amfensch2ARM5
There is only one type of load that applies a linearly-varying load: Hydrostatic pressure.
The pressure at a depth is p = x*density. Based on the width of the flange and length of 9 feet, you can work out what density you need to give 3 kip/foot at the 9 foot dimension.
John.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
