Dimension Angle from Vertical
tranq006
tranq006
Hello All,
I am trying to dimension the angle in this image from the vertical instead of the horizontal. In other words, I want to show the 5 degree angle with the vertical. Because there is no vertical geometry there, I cannot figure out how to do this. Is there a workaround? ThanksScreen Shot 2021-08-09 at 1.28.17 PM.png
mango.freund
hi, take the vertical one from the middle by .375. greetings mango
etfrench
As @mango.freund says: Use a vertical reference line to measure from.
ETFrench
tranq006
Hello, while this does give a dimension of 5 degrees, it is not aestheticallyScreen Shot 2021-08-09 at 3.22.51 PM.png pleasing (see attached).
jhackney1972
If you do not like the way the 5 degree angle looks with their suggestion then your only alternative is to add a small auxiliary sketch, in your model, make it visible in the drawing and dimension to it.  See the Screencast.  You can also dimension the included angle, which most detailers and machinist like the best anyway.
John Hackney, Retired
